On a 1976 Viper, what was the purpose of the splash well? I have seen guys are closing in the splash well when redoing a Viper or Vulture. What is the best way to go...keep it original and have the well or enclose the well altogether?
When I pulled out the transom, it was all rotten around the splash well drains. Was worried about putting these drains back in, even though they are needed if I keep the well.
Splash Well question
- Been thanked: 12 times
Re: Splash Well question
I'm recoring and putting a new transom in my Viper as well. I decided to keep the splashwell for the strength it must add to the transom area. From my experience working with metal, the more curves and bends make the steel piece stronger. After cutting the fiberglass splashwell to get to the transom, couldn't help but to think all those curves and corners have to make it stronger like it does with steel.
If my thinking is incorrect, than it least it will still look original. I even went ahead and added a gusset in the center of the splashwell also. Good luck with your project.
The main reason for the splashwell is to keep water from coming into the boat when you slow down really quickly and that is about it. It really has nothing to do with strength. 90% of the time when guys do deck it over they are also running some knees from the stringers to the transom for added strength. Most people dont replace it as its easier to deck it over and I personally think it looks much better that way.
Now if you have a beautiful original metal flake finish like Jeff does on his Viper, then I would find another way of doing the transom (i.e. Pulling the deck off) cause I could not come to grips with cutting the original splashwell out and then trying to replace it and match the gel and all of that.
Its all personal preference really. I am removing the splashwell on my Vulture and decking it over.
Thanks for the info. Deck is already off the hull, so I will plan on keeping the well.
Uhhhhhh, the splashwell gives you a place to clamp on the motor???
Remember, when these boats were designed, there were no V-6's, engines used thumb screw clamps, and jackplates were almost unheard of.
I would have to agree here. With the way we do things now days I forgot about that. I know my dads old hustler wildcat, if it wasn't for the splashwell, we would have swamped the boat time and time again. LoLtransomstand wrote:Uhhhhhh, the splashwell gives you a place to clamp on the motor???
Empty beer can holder
- 3265 Views
Mar 03, 2012 10:54 am
- 19Replies
- 13088 Views
Mar 06, 2012 8:32 pm
- 3032 Views
- Last post by streamin_demon
Mar 04, 2012 10:38 am
- 4068 Views
Mar 04, 2012 1:27 pm
- 4197 Views
- Last post by ConFuseee
Mar 04, 2012 7:54 pm
