Bob's low water pickup install
Ok I started with a used nosecone and my stock 200 gearcase. I thought I had more pictures but I didn't but I got the important parts.
I started by test fitting the cone and using modeling clay on the case. I used a aluminum bit in my dyegrinder to fit it as close as I could. I was also on a tight timeline to get it done so I could have spent more time and used less filler but oh well it's done.
Once it was close I filled the nosecone with marine tex and taped it in place to set up the next day I welded it on in 5 spots about 3/4 inces each. A picture would be nice but like I said.... The welds were at the top just above the bullet and one on the bottom by the skeg. I then used more marine tex to fill in any gaps and make a smooth transition from the nosecone to the case.
That was the easy part now at this point you need to drill a large hole and tap it under the waterpump. I spent about 3 hours trying to measure everything so it would come out right. The hole hase to be perfect if it's too far back it will hit the wall for the exhaust cavity, too far forword it will hit the upper bearing for the driveshaft, and too high it will hit the water pump base plate.
As you can see I was just a bit too high but I got lucky and the base plate still seals.
You will need to grind on the front edge of the cavitation plate for the fitting.
At this time I used polyester with some cabosil to fill the old pickups, I just taped them off and filled it from the top.
I then taped the hole and connected the hose.
I then sanded it smooth and plan on waiting till winter to have it finished up and painted. It works gerat and took about 7 hours to do.
- Has thanked: 351 times
Re: Bob's low water pickup install
Looking good. Looks more time consuming than anything.
Ya it took some time, I had no idea how to do it so I just winged it and it turned out has held to 85 so far. Next project is to convert from the clamshell cowl to a later model opti that I have on the shelf. Powrehead will have to come off, I just had it off last week for the solid mounts.
Chet, did you block off you normal water pickups on the sides of the case? I'm spiffing my case up and I was told to fill the pickup holes in with marinetex and fill the cavity in with epoxy resin up to just below the fitting for the lwp. I mean the fitting that goes into the case. I know a lot of people do fill the side intakes but It'll hold water though. Just wondering what you did. Thanks. Rick.
Ya Rick that's how I did mine, but I used polyester and microballoons to fill it up just under the fitting. I still took it off this fall and brought it into the house.
I bet you're itching to get out.
Ok, I'll do the same. Dude! It's more than an itch, it's a rash now!77viper wrote:Ya Rick that's how I did mine, but I used polyester and microballoons to fill it up just under the fitting. I still took it off this fall and brought it into the house.
Oh by the way, you got any used temp senders layin around? The nut wouldn't come off of mine and now it's open circuit. I'll buy one off ya. Thanks
your looking for a temp gauge right, I only have a set of factory senders.
The sender that goes in the left head. How much?
Chet when you installed the Bobs LWP was the cone tip even with the center on the prop shaft
Yes I centered it and it seamed to work fine.varmint1 wrote:Chet when you installed the Bobs LWP was the cone tip even with the center on the prop shaft
- 43Replies
- 62537 Views
- Last post by Steve Slechta
Sep 05, 2013 3:58 pm
- 4359 Views
- Last post by HST4ME
Jan 19, 2013 12:23 pm
- 7775 Views
Jan 21, 2013 10:08 am
- 8302 Views
- Last post by mitchielpricer
Jan 06, 2014 7:19 pm
- 10357 Views
- Last post by LSaupe
May 15, 2013 4:11 am
